http://www.ronayers.com/Fiche/TypeID/26 ... roup/FRAME
I seem to have lost item 23 on one side of the bike.
I tried an M10 nut last night but it seems the thread is different.
I plan on going to the fork handle shop after work to try and get a new nut but Im unsure what to ask for???
Is it a parallel thread or something?????
ta in advance Jazz
Rear Subframe bolt
Rear Subframe bolt
Everything good is bad
Everything bad is good
Re: Rear Subframe bolt
Secure the subframe and take off the remaining 23 nut from the other side and take that in as the pattern to match.
Problem with that one Wicky, bike is in Kirkcaldy I work in Perth.
std M10 is a 1.5mm pitch, if that didnt work, then it is a fine pitch which is 1.25mm
Just notice on this page http://www.ronayers.com/ProductDetails/ ... KU/1117648
That the same sized nut is used on the indicators. I have broken indicators in the garage so wont need a new nut.
Cheers Jazz
Cheers Jazz
