Main jet sizes ?
seantopbloke
Main jet sizes ?
Post by seantopbloke »
Ok, my question is this,
why are the main jet sizes different between front & rear carbs yet when i ftted the Dynojet kit i fitted an equal sized pair of jets ?
Its the sound of thunder at the back end that makes me smile at the front end !
Re: Main jet sizes ?
I was told it was because the rear cyl gets hotter, so run it a bit richer
darkember
Post by darkember »
Carrying this thread on then what would be the main jet sizes for a Stage one setup: IE: Front Jet size & Rear jet size.
what filter & cans?
k&n & unbaffled cans, 180 / 182 - 182 / 185
thats keihin jet sizes btw not dj - you can get them off ebay 1.99 each
best to shim the std needles as well rather than use the dj needles.
m4 brass washers from b&q, few £ a pack
i had bmc in mine & was running 200 / 205 mains with 50 pilots = 70 - 90 miles to the light
pilot jet part numbers are here somewhere if you search with my name.
