Done the 19l tank mod
Added a Varadero tap.....works well, T piece and now a VFR fuel level sensor and gauge....
Guage was £5.00 off fleabay
Adjusted the level sensor from the vfr to have a kink and then tested it, to adapt it for fuel level....
18.4 liters from empty to full
10l out to half on the gauge
further 5l down to qtr (reads red) then 3 ltrs down to empty.
The 19l tank is set in such as way that the last drops can't be drawn out as they are above the tap even with a pump it is impossible to get the fuel..out
19l Tank plus Fuel gauge
- Stormer Dave
complex personalities lead you to v-twin happiness......if you can get to turn in.......that is.....
