K n N filter
bluestoesonnose
K n N filter
Post by bluestoesonnose »
Hi, My bikes got a KnN filter fitted to it, I've had mixed results with them in the past, is it worth keeping or is changing to a standard Honda filter the way to go?
Blues
Re: K n N filter
depends if its been set up to run on the k&n...
if it's had a dynojet kit fitted it will most probably have an extra hole driled in the slide.
probably easiest way to see is pop off the rear cyl diaphragm cap & have a look if it has a 2mm hole right through the slide...
Re: K n N filter
If it has been rejeted and the power curve feels nice and linear with no dips and holes, then keep it, if it has a dip around 5000 revs,then you have 2 choices.
A) spend more time trying to get the jetting sorted for the K&N
B) pop a standard one in and see if it feels better.
