Indicators flashing to fast help please
hello all had this in another post ,so this area would be better ,when i got my bike last week my left hand indicator flashed to fast
Ive now changed them to after market indicators and they all do this they are not LEDS just normal bulbs
one member has suggested it could be a dodgy earth how can i check and fix it if this is the case ?
,im not to clued up about electrics but willing to try owt
Another thing is i have to keep my thumb on the switch for a good few seconds before they work this drives me bonkers
I haveva new relay coming incase it this
Thannks in advance ,
Any members selling a manual i think i need one
Loud pipes save lives!
Spray some wd40 in to the switch gear it should help
Re: Indicators flashing to fast help please
Ill try that i did think that might help
I went into my shed and found a can of it and it was empty damn it
ill get a can tomorrow
Instead of WD40, buy contact cleaner, that's what it's designed for.
- bucklandswifty
- Contact:
Switch cleaner is the right thing. I have a similar issue with my indicators, when it's cold ( <5C ) they take around 4 seconds to come on, temperatures above this they come straight on. I have cleaned with switch cleaner but no change. I am thinking it must be something to do with metals contracting in cold weather. When I have time I will have to take the switch apart to see what goes on in there! Chris
No one ever damaged their eyes by looking on the bright side!
it may be the bulb wattage is different (read wrong)
fitted new relay today still the same sprayed the switch leave to soak in ,then ill check it how do i solve the bad earth or check its bad????
What i know about electric is dadgy but will to have a go
post a pic of bulbs in indicators, some of the new led ones look like normal bulbs
http://lincsrideouts.co.uk
- babysitter
Just fitted after market indicators to mine they came with 12v 10w bulbs had to change to 12v 23w bulbs to fix fast flashing fault
Harley Davidson Roadking 1690 / Harley Davidson 1200 Sportster
54 Honda Varadero XL1000 / Honda Firestorm Red,/ BSA B40WD Trials,
/Audi TT 225 / Foard Transit T300/ VW Touareg
ill say again
WRONG WATTAGE BULBS AT ALL??????
cheers mate what watt shall i buy
babysitter wrote:Just fitted after market indicators to mine they came with 12v 10w bulbs had to change to 12v 23w bulbs to fix fast flashing fault
those maybe?
what are you doing with your front indicators? i have exactly the same ones as you fitted but i want standard ones instead
Second person to ask it came with diffrent ones to standed ,the same as the ones ive fitted but with amber lenses sorry mate
