Engine Breather
bluestoesonnose
Engine Breather
Post by bluestoesonnose »
Had the bike running without the timing plugs fitted as I've just fitted manual CCTs, I couldn't believe the amount of air being pushed out and pulled into the hole. Why don't these motors have crankcase breathers the size of fire hoses?
Re: Engine Breather
It's possible to connect a breather to the oil filler hole, but actually the air inside acts as a spring, not a pump, so as the pistons come down you lose a little energy compressing it, but get it back as they go up again.
It's a bit more complicated than that, as they don't go up and down together, but the principle still applies to a degree.
Another possibility is running lowered crankcase pressures, (a partial vacuum) which means that all of the seals need to be in really good condition, and hope that the half-moon rubber cam cover seals don't get sucked in, allowing lots of oil to be blown out.
I've disconnected the breathers that go into the airbox and routed them to a catch tank and breather outside the airbox, mainly, to be fair, because I wanted to increase the airbox volume.
darkember
Re: Engine Breather
Post by darkember »
tony.mon wrote:It's possible to connect a breather to the oil filler hole, but actually the air inside acts as a spring, not a pump, so as the pistons come down you lose a little energy compressing it, but get it back as they go up again.
By this you mean the breather pipes off the rocker covers? Any photos of the catch tank & location?
Re: Engine Breather
I'm thinking about making a breather bottle with a oil drain to the front sprocket cover so that if any oil enters the bottle it will help lube the chain . As I haven't seen any oil in the breather pipes that I fitted for the gutted airbox I can't see it being a problem .
Any thoughts ?
Re: Engine Breather
Why not just feed a tube down there and keep the bottle high and out the way.
