Engine whine ???
Diabolus
Engine whine ???
Post by Diabolus »
Engine sounds whiny when under load any ideas ??
I swapped ccts for manuals over 1700 miles ago and backed them off once as I thought they were a bit tight and seemed fine.
http://lincsrideouts.co.uk
Re: Engine whine ???
mine does that in first gear only so i just give it a hand full so all i can hear is the induction noise :twisted:
Diabolus
Post by Diabolus »
Its different to the first gear whine its only just started doing it. Its when on the throttle any gear.
vtwin
Post by vtwin »
Chain & sprockets worn? :wink:
Diabolus
Post by Diabolus »
Did them just before ccts, this is definatly engine related.
vtwin
Post by vtwin »
Is the noise speed or engine revs related?
Try undoing both cct's two flats, and see if it makes any difference.
But overtight cam chains make a squeal on startup which goes away once oil pressure gets up.
That doesn't sound like what you're describing, tbh.
Diabolus
Post by Diabolus »
I'll try that tony just can't think what it is ?? Its annoying And just think as I'm riding somthings not right and Im doing harm to the engine.
Is there any specific area the sound is coming from. can you pin point it to one side or the other. I'm thinking water pump, isn't there an impeller inside it. This may be starting to seize causing a wine or squeaching noise as it spins.
Just a thought, but it would definitely help if you could try and pinpoint the sound.
seb421
Post by seb421 »
My last engine developed a whine I couldn't identify about 5k after that it started the knocking from the crank
Sent from the Bat Cave via Cup and String
Maybe someone nearby can be of assistance.
Unfortunately you haven't put your location in your details, so don't know where that is.
Diabolus
Post by Diabolus »
Oil level is near the lowest mark, I'll top it up and check cct tension. I will be at the 'old vic' in september are any of you ?? Tony ect ....
Yeh there will be a few of us there, have a look at the attendees list here http://www.vtr1000.org/phpBB3/viewtopic ... 53#p203697
Diabolus
Post by Diabolus »
I topped up with some more castrol power 1 , took 500ml I've been out with my daughter on the back and the whine has gone ! its there at pre 4K rpm (quiet) and gone post 4k rpm as was used to be, just an animal awaiting some 8k-9krpm fun (without whining)!! lesson learnt keep the storm at top of oil mark or hes not happy !!!
I know that the filler cap is leeking as its not the right one as it moves from side to side when nearly tightend im gona go for a pro-bolt one asap. :thumbup:
alternative_vtr
Post by alternative_vtr »
Hi, I think they do whine a bit, mine does a bit and so does so does another I know of. Sort of a whistle / feint whine v-twin noise................... I'm not making sense am I................ I'll get my coat :roll:
KTM Duke 690ABS in White
