Page 1 of 2
Newbie
Posted: Fri Aug 03, 2012 9:29 am
by warlock
Hi All
Just got hold of an 1998 VTR Firestorm that needs a bit of TLC. Gradually stripping her down and replacing as ness...
Hopefully you guys and gals can give me some advcie when i ask?
Neil The Warlock...
Re: Newbie
Posted: Fri Aug 03, 2012 9:42 am
by AMCQ46
welcome to the Club Neil, hope you enjoy the bike. have good read in the workshop knowledge section and make sure you sort the CCTs when you are sorting the bike out.
also worth putting your location in your user information so you can perhaps get some help from anyone local.
Re: Newbie
Posted: Fri Aug 03, 2012 10:11 am
by lloydie
Welcome and hello :-)
Re: Newbie
Posted: Fri Aug 03, 2012 10:17 am
by VTRDark
Welcome :beer: :beer: Have a good read through the workshop knowledge base plenty of food for thought there. And yes CCT's should be checked also the regulator Rectifier should be changed for the finned type.
Some links regarding the Cam Chain Tensioners (CCT's)
CCT's can go at any time, it's a gamble!
You can either go for the stop mod http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416 Which is the Honda auto CCT's that are converted to a fail safe. So when it does fail, it don't send the valves crashing.
Or
You go for the full manual conversion, your options are here http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=22720
Then with regards to fitting View Topic View Topic http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
To see if it has been done have a look at the CCT's on bike. Is there a thread coming out the end with a locknut. If so then manuals are installed.
Regulator rectifier you will find attached to the subframe just behind the tail panel on the right hand side near the battery.
Re: Newbie
Posted: Fri Aug 03, 2012 10:53 am
by agentpineapple
hello and welcome, as above, put your location because a fellow member could be just around the corner and they might be able to help..... :thumbup:
Re: Newbie
Posted: Fri Aug 03, 2012 11:09 am
by alternative_vtr
Hi, welcome. I am new too but already people here have been incredibly helpful. I will try and give back where I can so just ask and people will do there best. The bike seems to be very reliable but as said the main two things that need doing are changing the cam chain adjusters to manual ones and changing the regulator/rectifier to a finned one to dissipate heat better.
Enjoy your new bike :)
Re: Newbie
Posted: Fri Aug 03, 2012 11:48 pm
by Flatline
Welcome aboard buddy
Re: Newbie
Posted: Sun Aug 05, 2012 12:11 pm
by warlock
HI Guys
Thanks for the welcoming, changed my location, Hemel Hempstead...
I have only just got the bike and havent even ridden it yet as it had been down the road, all the normal damage, Brake Lever, Rear Foot Lever, Clutch Cover and Basket, indicators, fairing scratched etc etc...Not too bad really. The bike was given to me so it has only cost me a couple of hundred ponds so far, so a real bargain if i can get it back on the road soon...
Originally I was going to just get the bike back on the road and sell it to get a crosser, but after discovering this website, i am now leaning towards keeping it as it hasnt cost me that much so far.
Only been on this site for a few days but the mods and memebers bikes are getting me the buzz again and making my mind work overtime with how far to go with it...
Took the sump off the other night as need to check for bits of clutch basket (there was only stones fromt he road) and had a good look underneath inside the bottom end, looks really clean in there, hopefully a good sign?
The bike has done about 25000 miles so not sure if the CCT's have been done and the friend that gave me the bike wouldnt know either, how can i tell or know if they need doing?
Or should i just do them anyway just incase???
The only part to actually get the bike running that i cant find cheap is the Clutch Cover, Honda want £240 plus VAT and they are like rocking horse on ebay!!! I might bite the bullet on this but is there anywhere that you guys know i could get one from and i see a few Carbon Cover Protectors on some members bikes, are these available anywhere???
Your help appreciated.
I might copy and paste this post in general chat too?
Cheers Neil
Re: Newbie
Posted: Sun Aug 05, 2012 1:30 pm
by VTRDark
Sounds like you have caught the bug and that's without riding it. you will have double the bug then :lol:
CCT's to see if it has been done have a look at the CCT's on bike. Is there a thread coming out the end with a locknut. If so then manuals are installed. To know if the Honda autos have been converted to fail safe, as far as I'm aware the only way to know is to remove the CCT's and look.
Heres a pic ot a rear manual one.
Just keep your eye out on ebay for the casings, they do come up from time to time. Carbon Cover Protectors can be bought from a German firm. I haven't got the link right now but I'm sure someone will post it up, or do a search and you will find a reference to them somewhere on here.
Re: Newbie
Posted: Sun Aug 05, 2012 2:00 pm
by Kev L
Re: Newbie
Posted: Sun Aug 05, 2012 7:01 pm
by warlock
Many thanks
Re: Newbie
Posted: Mon Aug 06, 2012 4:57 pm
by AMCQ46
The clutch cover is one of the bits that gets damaged too easy so the 2nd hand ones are very rare, or also damaged. but one option is to get one with only mild damage, repair it [if it is holed] and then stick the carbon cover over it. costs way less than the new one and will protect the engine if the bike gets dropped again
Re: Newbie
Posted: Mon Aug 06, 2012 5:14 pm
by VTRDark
I'm after a clutch cover as well as I fancy having a go at putting a window in it like this one.
http://www.superhawkforum.com/forums/mo ... ine-21805/
Might do the same to the sprocket cover as well.
:biggrin
Re: Newbie
Posted: Mon Aug 06, 2012 6:02 pm
by Miff_UK
cybercarl wrote:I'm after a clutch cover as well as I fancy having a go at putting a window in it like this one.
:biggrin
Hmmm, think I have one in the shed, i'll let you know
miff
Re: Newbie
Posted: Tue Aug 07, 2012 12:19 am
by tony.mon
:biggrin
miff
Just checked, I have a window in my shed as well.
Coincidence or what.....??......!
:wave:
