PAIR System removal
E.Marquez
Re: PAIR System removal
Post by E.Marquez »
macdee wrote:There was something on the superhawk site about this I think the best way to remove the pair system was just to flip the the read valves over and put cover back on
That is a a way.
I found the occasional engine stumble and pop would cause the seal to leak eventually..
So I drilled and taped threads in the valve cover hole for the pair system and installed a threaded plug
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
cybercarl wrote:In that case we are fuooked anyway. :lol:
Back to PAIR. I'm wondering whether that O ring and Collar are needed if earlier Cam covers are put on. :think:
The small Collar and O ring lead to hole drilled into the exhaust port so the injected air can get into the exhaust system.
I'm not sure if your early models have the hole drilled but if installing on a bike that has the PAIR removed they will be needed or you will have either an exhaust leak into the valve cover or a direct path for oil to leak into the exhaust if you do not install the collar.
I've run mine for the last 14-15 yrs with the reeds flipped, covers installed and the collar in place with no ill effects so far :thumbup:
darkember
Post by darkember »
I also flipped the reed over & have had no issues
chris freckle
Post by chris freckle »
If you drill & tap the hole in the head below the valve you can locktight a headless bolt / screw in there & the problem is curred. Dont let any swarf go down into the exhaust port!
darkember
Post by darkember »
chris freckle wrote:If you drill & tap the hole in the head below the valve you can locktight a headless bolt / screw in there & the problem is curred. Dont let any swarf go down into the exhaust port!
Personally I would just flip the reed over & bolt it all back down using the blanking plates supplied in the kit. Below is the kit I used:
https://tpoparts.com/cat093/index.php?r ... duct_id=62
Now I know the exhaust feed hole needs blocked off .
Thanks guys .
With these blanking plates are the just flat plate or stepped ?
lloydie wrote:Now I know the exhaust feed hole needs blocked off .
Thanks guys .
The first set I made were just flat and worked fine.
The second set I made were stepped to copy the stock bits and they worked fine also.
So I guess the answer is Yes..... :beer:
Great I will have a go at making some . Thanks mike
PAIR System removal
Some pics I took today from virts scooter .
This is the exhaust feed that runs from the exhaust port to the reed valve in the cam cover .
This is the pair cam cover in side view
That looks just like the non pair cam cover Image
By having. A good look today the old cam covers will fit and there will be no need for blanking plates .
E.Marquez
Post by E.Marquez »
lloydie wrote:Some pics I took today from virts scooter .
Right o.. good job..
SO you'll only have that one O ring left that could leak..
Were it me.. (and it was) drill and tap the passage in the head... screw in a socket head tapered thread plug, and never again think about it.. the exhaust passage for the PAIR will be sealed forever.
Post event services
Total Rider
looks like it and i do like the idea of permanently plugging the exhaust feed hole :thumbup: but as its not my bike i wouldn't attempt it .if it was mine then yes id plug it .
for its owner an O ring is easy to change the same time as the valve clearance check so its not that much of a issue .
Virt
Post by Virt »
If you like the sound of it, you're more than welcome to attempt it lloyd :lol:
Virt wrote:If you like the sound of it, you're more than welcome to attempt it lloyd :lol:
not on yours but the cam cover swap and pair removal next time your round is a go if you like
I can confirm that replacing the cam covers for non pair type and blocking the hole in the air box bottom and also blocking the small vac feed to the pair gizmo works .
Might be easier than trying to get the kit from the USA :-)
thunderbolt
Post by thunderbolt »
Can someone explain to me where the "O" ring and collar are? If I put the blanking plate on the valve cover where are the afore mention bits in relation to that? And how does the oil get into the airbox if these are left out?
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
