oil leak
oil leak
after finding an oil leak around one of the bolts holding the rear rocker cover in place, i think i've come up with the problem, i believe there should be a rubber mounting washer under the bolt, this isn't there.....grrrrr
god knows where its gone
whats david silvers phone number again :lol: :lol: :lol:
can anyone confirm there should be a rubber washer there???????
Re: oil leak
Here you go mate number 8
http://www.lingshondaparts.com/honda_mo ... ck_03=6088
http://www.davidsilverspares.co.uk/
You may be able to use a rubber washer from a hardware store. A tap washer maybe be the right size. It would at least go as a temporary fix :thumbup:
Re: oil leak
sorted, phoned motoden honda who ha several in stock, the robbing basterds....£3.50 each :eek2
i have previous history with them.....grrrrrr!
anyways bought and fitted, and now know oil leaking fingers crossed....... :thumbup:
Jazzscot
Re: oil leak
Post by Jazzscot »
Did you check that you hadn't accidentally put 2 washers on one bolt when it was off previously??
Everything good is bad
Everything bad is good
Re: oil leak
Jazzscot wrote:Did you check that you hadn't accidentally put 2 washers on one bolt when it was off previously??
nope....
i wasn't the one who put the rocker cover on last.....hahaha
its a good point tho, i will check it out tomorrow before riding the bike...... :thumbup:
Re: oil leak
They often stay stuck to the bolt head, but sometimes they stay stuck to the rocker cover, so you have to check they've all got one (and just the one) on reassembly.
It's metal side up, btw, and it's marked with the word UP, just to make it foolproof.
Re: oil leak
tony.mon wrote:They often stay stuck to the bolt head, but sometimes they stay stuck to the rocker cover, so you have to check they've all got one (and just the one) on reassembly.
:oops: :oops: :oops:
i think i put them in the wrong way up
not totally fool proof ten
Re: oil leak
He said fool proof, not Marty proof, clearly the two are not the same...
Re: oil leak
I suppose your propensity for parking it upside down doesn't help with the orientation of the seals either!!! :lol:
Re: oil leak
Very good Kev :lol: :lol:
Marty the seals are the right way around, well they are on the front anyway. :lol:
Re: oil leak
nothings leaked yet so its all good chaps, and kev sometimes i think riding with two wheels on the tarmac is very restricting.... :lol:
Re: oil leak
bigspanishmarty wrote:nothings leaked yet so its all good chaps, and kev sometimes i think riding with two wheels on the tarmac is very restricting.... :lol:
Blue sky thinking, outside the box there fella. Takes a strong man to buck against conformity and tread your own route. Mad as a box of frogs mind!!!!!1 :lol:
