caliper service
BigVeeGrin
caliper service
Post by BigVeeGrin »
Quick question - is a caliper service something an inexperienced keeno like me could do? I've checked out the various threads on it. One thing to bear in mind is they have taken a beating over the years coz they're on a black bike :wink:
Re: caliper service
BigVeeGrin wrote:Quick question - is a caliper service something an inexperienced keeno like me could do? I've checked out the various threads on it. One thing to bear in mind is they have taken a beating over the years coz they're on a black bike :wink:
PM Jonesy the braking guru of all things Storm, he will put you right. I think the only thing that's gonna be tricky, with out the right kit is removing the pistons. Oh & if they are standard you will need an E12 socket to split the callipers (couple of £'s from halfruds, or I can lend you my one if you don't want to invest.)
Jonesy has to have great brakes as he has a red one. :wink:
Mac
Re: caliper service
It's very easy to do .
Get all the new seals before you start and new bolts and some red rubber grease and new brake fluid .
Take your time and make a note how they come apart .
Keep the callipers separate .
Check the pistons for pit marks and replace . I have done spare piston if you need them .
Re: caliper service
It's easy to remove the pistons . Just pump them out .
And you can use a 8 or 10mm socket on the caliper bolts .
Re: caliper service
Not if they are like what mine where like. Even with jonsey's puller tool they struggled to pop out. And then to top it all off my fluid had all jellified like treacle. :lol: Brakes where so much better afterwards.
Re: caliper service
Brakes need a service just like the engine . Do them yearly at least
Jonesey
Re: caliper service
Post by Jonesey »
Send em to me I'll do them for postage.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
Re: caliper service
Jonesey wrote:Send em to me I'll do them for postage.
Highly recommended :thumbup:
If your put off by having your bike off the road I have a full set of calipers that your welcome to borrow to keep you on the road.
Mac
Xenocide
Re: caliper service
Post by Xenocide »
If you have an air compressor then it's a piece of piss getting the pistons out. Get an old brake line or a banjo and chop the end off so you just have banjo with some hose on it, then put your air gun in the end and pulse the button, the piston'll come right out. You might have to put a small g clamp over the other pistons to ease them all out at the same rate if they're a bit sticky.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Re: caliper service
I like that idea, very clever. Mine where near enough seized in place. Once the pistons where out I had to wet n dry the rust off them.
BigVeeGrin
Re: caliper service
Cheers Jonesy & Mac appreciate the offers :thumbup: . Think I'll give it a go - only way I'll learn. Now if I Great Uncle Bulgaria it up you may seeing them!
BigVeeGrin
Re: caliper service
lloydiecbr wrote:Brakes need a service just like the engine . Do them yearly at least
It was you Lloydie who told me to get on the case!
Re: caliper service
Was it !
Memory short but the days are long !!!
Re: caliper service
There you go with the philosophic comments again. :thumbup:
BigVeeGrin
Re: caliper service
lloydiecbr wrote:Was it !
And, it seems, the nuts are gone!
