If they are race ones they won't have a break light fitting
I didn't realise they made a road or race version. And yes the add did say missing spacers BTH I havent a clue what spacers he was on about, so I presumed he meant spacers as in big washers to go behind then on the spindle.
Well I managed to get the master cylinder on, but the pedal ended up at a stupid angle as the length at the bottom is too short. I think one of those banjo type attached that Lloydie posed will be the solution there. 1st it will extend it and 2nd it will be a better figment where it attaches on the rearset.
have a look
As for the brake light I am going to have to look into that, it's also where the spring is going to attach on the pedal. Don't know much about the inline type so I will have to research that. And then there's the issue of how to attach the return spring on the pedal.
So all in all not a straight forward swap
Oh and something else.
Not that it makes much difference but it does mean I have to put either a spacer or a bunch of washers on the small allen bolt fixing point that's on the front as there is a gap behind.
I have put it all back to standard for the time being.
