starter motor replacement
what other starter motors will fit vtr, is tony mon out there he is god.
thanks
john
thanks
john
Re: starter motor
Yes he isis tony mon out there
Re: starter motor replacement
thanks but no help
Most Hondas from late 90s - Blackbird, Hornet etc.
Alright, I've finally logged on. Been busy....
Actually, almost any Honda motor for a bigger cc bike will do, because you can disassemble the old motor and use the end caps off one with a similar centre section, such as an Sp1 or 2 motor....
Just make sure the shims leave you with the correct end float. Haynes should tell you what that is.
But is it just the burnt out cable attachment bolt that is causing you to look for a new one?
If so, it's simple to strip and cut a large-headed bolt to fit. Once apart you'll see what I mean.
This may be of help if it is the bolt that is at fault http://www.vtr1000.org/phpBB3/viewtopic ... 15#p230910
hi thanks all
cut nut off bolt clean fit new nut,going to replace bolt.just want cheapest replacement to practice on,as prices vary firestorm 50 to100 blackbird 30 to60
hornet 15 to60 handy to have spare just in case.
thanks john
thanks john
mine is off a `99 blackbird.............
- benny hedges
why use a different one? ive got a good spare if you want it.vtrman44 wrote:what other starter motors will fit vtr, is tony mon out there he is god.
thanks
john
thanks benny
watching some on ebay,but firestorm starters,are silly money.so looking for a cheaper option . short on cash at present. pm me to let me no price.
thanks john
thanks john
- benny hedges
pmd
If one's available to collect locally and at the right price it gets you back on the road quicker than waiting for the correct one's auction to end.benny hedges wrote:why use a different one? ive got a good spare if you want it.vtrman44 wrote:what other starter motors will fit vtr, is tony mon out there he is god.
thanks
john
-God (apparently)
