Slightly darkens paint but sheets very good
That's not bad considering buying 2nd hand pipes would cost the same. And with the coating they wont go rusty all the time. It would be nice to see some pics once you have that done.getting my headers ceramic coated.. probs go for gunmetal finish cos apparently the back fades over time.
£60 for the full system
I just wiped it on left for a while about two cigs and a cup of teacybercarl wrote:It looks like you got it on the camera lens as well in the first few pics. What's it like to apply, does is dry into a milky powdery colour like wax when ready to wipe off or is it a case of applying a thin layer then wiping straight off and allowing to dry.
It's certainly got some shine to it though it's hard to tell cause you bike is in such pristine condition anyway. The tree reflection on the tank is crystal clear.![]()
I can't see how it would do any harm. Apply once in in one direction and once dried apply another coat in another direction which will cover any spots you may have missed the first time. 5 years does seem a bit optimistic, even if it last for a couple of years it's not a bad thing as it should even strengthen the paint so should withstand stone chips and stuff. I wonder how it would compare to the CQuartz UK edition.i applied two coats which later found out i should not haveso some one says on dw.
They are not pics, they are vids. Click to watchcybercarl wrote:It looks like you got it on the camera lens as well in the first few pics. What's it like to apply, does is dry into a milky powdery colour like wax when ready to wipe off or is it a case of applying a thin layer then wiping straight off and allowing to dry.
Are they happy to coat old pipes or do they want unused pipes? I know chrome platers won't take on pre used exhausts as it ruins their plating fluids when you introduce carbon from old exhausts. I must admit to not knowing how the ceramic coat is applied to them.benny hedges wrote:getting my headers ceramic coated.. probs go for gunmetal finish cos apparently the back fades over time.
http://camcoat.com/main/site/
