trailer hub spacers
Jazzscot
trailer hub spacers
Post by Jazzscot »
Anybody got any ideas where I would be able to get a new spacer.
I'm currently playing about with an old caravan chassis that has a dodgy wheel hub. Took  it apart and found out the wobble to the hub was caused by the spacer on the right of the photo had worn down.
It should  be the same length as the one on the left
Tried a few Google searches but was wondering where I could get such a thing.
Everything good is bad
Everything bad is good
Re: trailer hub spacers
Probably best to find a local engineering firm.
Get them to copy the good one & make two while they are doing it, so you can put two brand new ones on.
edds11
Post by edds11 »
local caravan /camping shop
MacV2 wrote:Probably best to find a local engineering firm.
+1 and wont cost much .
if you cant find anywhere send me the measurements and i will have my guy make them for you .
simo
Post by simo »
Maybe a section cut off a scaffold pipe????
Theres A Hare in The Turnips.
simo wrote:Maybe a section cut off a scaffold pipe????
But not while the scaffolder is watching.
