Oil level where should it be?
chric
Post by chric »
info please
Re: Oil level where should it be?
With the bike upright you have a high and low level mark in the the little window on the clutch case, so anywhere between those two lines is good. I generally check/fill up to the high mark when the engine is cold as all the oil would have sunk back down to the sump. :thumbup:
chric
Post by chric »
ta carl it needs toping up then may aswell get neil to drop it all and but fresh in me thinks :thumbup:
chric wrote:ta carl it needs toping up then may aswell get neil to drop it all and but fresh in me thinks :thumbup:
make sure its semi synthetic..........NOT fully synthetic........
chric
Post by chric »
already have two tubs of semi thanks :thumbup:
I have mine so its just viable in the window when its on the side stand .
Never had an problem
callam_nffc
Post by callam_nffc »
So what oil do you all use? Always used the expensive castrol one myself (Cant remember the name) and thinking about doing an oil and filter change soon
CBR125 - XJ600S DIVERSION - YZF600R THUNDERCAT - VTR1000 FIRESTORM
I still crave a supermoto...
Stratman
Post by Stratman »
cybercarl wrote:With the bike upright you have a high and low level mark in the the little window on the clutch case, so anywhere between those two lines is good. I generally check/fill up to the high mark when the engine is cold as all the oil would have sunk back down to the sump. :thumbup:
+1
