Page 1 of 1
Damn it!
Posted: Sat Jun 08, 2013 12:35 pm
by Redthunder
Up and over garage door cable snapped :'(
Re: Damn it!
Posted: Sat Jun 08, 2013 1:10 pm
by Hairy biker
Doh!
Re: Damn it!
Posted: Sat Jun 08, 2013 7:08 pm
by ANDYGEE
My sympathy's go out to you, happened to me a fortnight ago, and the other cable jammed with the door half way down, ain't doing my back any favours .
Re: Damn it!
Posted: Sat Jun 08, 2013 7:39 pm
by lloydie
I lube mine regularly :-)
Re: Damn it!
Posted: Sat Jun 08, 2013 8:15 pm
by Hairy biker
It happened to a friend of mine once, he said it was a right bugger to sort out so I've kept mine lubed ever since
Re: Damn it!
Posted: Sat Jun 08, 2013 11:30 pm
by Redthunder
I know the tricks. Was only 6 months ago I had to change the frame because it had rotted.
The trick is setting the tension right.
Re: Damn it!
Posted: Sun Jun 09, 2013 7:32 am
by Hairy biker
At least you know how to fix it, if mine goes belly up I'll give you a shout
Re: Damn it!
Posted: Sun Jun 09, 2013 8:07 am
by Redthunder
Am thinking of 2 longer term options...
1) roller shutter door
2) brick it up installing a conventional door just wide enough to get a bike in an out!!!!
Could always put bikes in lounge through French doors ;-)
Re: Damn it!
Posted: Sun Jun 09, 2013 8:13 am
by lloydie
Option 2 :-)
Re: Damn it!
Posted: Sun Jun 09, 2013 8:15 am
by Hairy biker
I like the third option
Re: Damn it!
Posted: Sun Jun 09, 2013 9:21 am
by MacV2
Up & over doors can be a pain to fix as said it's setting the tension right that is the issue.
As a quick fix you could always adapt the door to open using a couple of gate hinges. It can be done as long as the frame is solid & more importantly you have the room for the door to swing open, left or right rather than up & down.
I was thinking of ye old style flat hinges then I found these...
http://www.gatecontrolgear.com/?Gate_Co ... commercial
As for you snapped cable they can be replaced & the door saved I would check Yellow Pages to find a local 'Garage Door ' installation co.
Good luck getting it sorted.
Re: Damn it!
Posted: Sun Jun 09, 2013 10:00 am
by bikerpiker
Shouldn't be too difficult to fix, when i installed a 2nd hand door into my old wooden garage i bought a kit from ebay,which included new cones,cables and spindles, cheap as chips
http://www.ebay.co.uk/itm/Garage-Door-S ... 3a75460c4f
Re: Damn it!
Posted: Sun Jun 09, 2013 3:36 pm
by Redthunder
I will fit cables myself. Storm isn't currently going anywhere, 125 will fit through side door and vtr will have to live outside!
