Needing brass choke fitting
superhawk996xx
Post by superhawk996xx »
OK, Does anyone know anyone selling the brass choke retaining nuts? I really need two of them. Only one of my broke while cleaning carbs but I am going to just replace both of them. Also, does anyone sync carbs using a vacuum gauge? I am going to buy one being I need it for more than one job but I was going to buy the single and sync each carb with one. Is that possible?
Re: Needing brass choke fitting
gl_s_r, did make some of those brass choke nuts, I don't know if it was a one off, but you could always ask. Here's the link showing them (8th post down):-
http://www.vtr1000.org/phpBB3/viewtopic ... ss#p220643
For carb balancing I use one of these:-
http://www.ebay.co.uk/itm/UNIVERSAL-MOT ... 4d0f5dc834
Redthunder
Post by Redthunder »
While carbs are off fit vacuum hoses to each inlet point. Use rear to connect to fuel tap, front blanked off, or connect together with a t piece.Make long enough to be accessible and you can balance carbs whenever you like hassle free!!
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Destined4bikes17@gmail.com
Redthunder wrote:While carbs are off fit vacuum hoses to each inlet point. Use rear to connect to fuel tap, front blanked off, or connect together with a t piece.Make long enough to be accessible and you can balance carbs whenever you like hassle free!!
Good advice RT :thumbup:
Griff1977
Post by Griff1977 »
sirch345 wrote:gl_s_r, did make some of those brass choke nuts, I don't know if it was a one off, but you could always ask. Here's the link showing them (8th post down):-
I've had some off him recently. They're great. Griff.
Immediate plans:Clean it!
superhawk996xx
Hey I am new and I cant PM yet. Can someone get gl_s_r attention for me? I need to order two of them ASAP.
I sent him a message for you,
gl_s_r
Post by gl_s_r »
I don't have any machined up at the moment but I can take a set from the spare choke cable and carbs I have set up doing nothing at this moment.
I will PM you and give you a email address you can reach me on and we'll sort out getting them to you if you still want them?
Mark
