petrol tank
Posted: Sat Oct 12, 2013 3:12 pm
Hi to all, some advise please before I part with a few pennies.
I have had an issue with petrol coming through one of the breather pipes when the tank is filled to the brim, and after much investigation it seems the pipe within the tank (the one not easily seen) has a pin hole resulting in a replacement tank requirement (or don't fill it up to the top, but with the range on these bikes you need every drop lol!) My bike has the smaller capacity tank, so the question is does the larger capacity tank on newer models fit mine. Seems like a good opportunity to make life a little easier and travel a little further on a tank full if it can be done.
Thanks in advance
Best Wishes
Phil
Thanks in advance
Best Wishes
Phil
