Axle nut size
Virt
Axle nut size
Post by Virt »
Haven't got anything the right size to fit over the rear axle nut. What size is it so I can get the right socket? Thanks :)
Re: Axle nut size
Virt wrote:Haven't got anything the right size to fit over the rear axle nut. What size is it so I can get the right socket? Thanks :)
27mm IIRC.
lumpyv
Re: Axle nut size
Post by lumpyv »
hey virt , do you have a torque wrench? I believe its quite important not to overtighten it .
Virt
Re: Axle nut size
Post by Virt »
Yeah we have plenty of torque wrenches. As long as it's less than 300Nm :lol:
Thanks Mac :thumbup: figured it was about 27 or 28
Re: Axle nut size
Virt wrote:Yeah we have plenty of torque wrenches. As long as it's less than 300Nm :lol:
93Nm
FYI the other end is 22mm.
Virt
Re: Axle nut size
Post by Virt »
Yep. You were right, 22-27 and 93. All done now. Thanks a lot :thumbup:
The Haynes book of false truths had the torque, just not the nut sizes
Virt
Re: Axle nut size
Post by Virt »
That's one more smart price tea I owe you :wink:
Re: Axle nut size
Why are you playing with your nuts today?
Virt
Re: Axle nut size
Post by Virt »
Jamoi wrote:Why are you playing with your nuts today?
Chain was a little bit slack, so I adjusted it, cleaned it and lubed it up.
Re: Axle nut size
Ah right :clap:
Re: Axle nut size
Virt if you don't have a socket then you will have a spanner and a little extension handle in the Honda toolkit, you can use that. Use your bodyweight (foot) on the spanner/extension handle to undo and do up the nut.
