Be warned if you start this job be prepared for the long hall. Photos will follow but not for a while.
I'm not intending to re-paint them they are going to a mirror polish & HT lacquer.cybercarl wrote:Why would you want to strip down to bare metal. All your doing is creating more work and expense for yourself. If it needs re-painting then give it a good rub down, key the surface. Wet n dry would be good, get it nice smooth and respray. There is absolutely no point in going back to bare metal and whatever primer you apply to the surface will never be as good as what comes out the factory. Your better off using it to your advantage.![]()
Argh OK that makes a lot more sense now. Hard graft all the way thenthey are going to a mirror polish & HT lacquer.
That's something I've not tried yet, although doesn't some of those have caustic in them, so you would have to be careful not to over cook themkenmoore wrote:Hey mate,
Oven cleaner is the go. I have used it on many parts including the engine cases.
Spray heaps of it on, let it bubble away, leave for 24 hours then hit it with sand paper or a dremmel.
Works a treat.
I would be interested to hear how that goes if you do ever give it a try Carl,cybercarl wrote:Mr Muscle cleaning packs for oven shelves may be worth a try. You place the product in the supplied bag, spray the cleaner all over and seal the bag and leave overnight. Come morning wash it all off. If the paint stripper does not work I would be tempted to give that a try. Maybe oven cleaners work like the old fashioned high VOC paint strippers.![]()
I'm interested in this method. My wife has used one but it is not a spray you just pour it onto the oven base & leave overnight. Could you tell me what product you used as it seems to work & not sure if the pour in stuff that we have may be too violent.kenmoore wrote:Hey mate,
Works a treat.
Then polish with varying grades of wet and dry, polish and hey presto it's done.
Then it's time to admire your handy work![]()
