What's This Then?
What's This Then?
My bike seems to have a bracket bolted into the end of the sub-frame - anyone know what is is as can't seem to find it referenced in either the Honda or Haynes manual. I guess I can remove it?
Re: What's This Then?
Looks like a rentec grab rail bracket to me, it should pull out of the end of your subframe.
Jamie
It will come off as it is not a stock part....where it is from I couldn't tell you but it is not from Honda
Okay, thanks guys - I'll remove it as I never carry pillions these days - bit more weight saving.....
It looks similar to my rentec carrier mounting frame
What's This Then?
Yep it's for the rentec sports rack and grab rail tho the rear plate is fitted backwardsFlatline wrote:It looks similar to my rentec carrier mounting frame
No but I'm sure Virt will give you a pearl necklace !!Jamoi wrote:Do I win some kind of medal then?
I just had to google that...lloydie wrote:No but I'm sure Virt will give you a pearl necklace !!Jamoi wrote:Do I win some kind of medal then?
I'm up for it Jamie
I'd lend you mine :-)Jamoi wrote:I don't have boobies though
Thanks Lloydielloydie wrote:Yep it's for the rentec sports rack and grab rail tho the rear plate is fitted backwardsFlatline wrote:It looks similar to my rentec carrier mounting frame
He doesn't want to triple his body weight?lloydie wrote:I'd lend you mine :-)Jamoi wrote:I don't have boobies though
