Re-fitted my exhaust system this morning and am not sure if I have done something wrong. I cannot remember for the life of me if the bottom of the linkage should be that close to the left hand exhaust bend. There is about 2-3 mm clearance. As far as I am aware the linkage is correctly installed with the arrow pointing forwards. Any advise much appreciated thanks.
Have I gone wrong somewhere??
Re: Have I gone wrong somewhere??
Believe I am going to be ok tested and as I bounce on the bike the distance increases.
Undo the rear clamp and Drop the rear collector down a bit and re tighten it up
I thought the same when I rebuilt mine but if you wiggle everything about a bit you can get it a little further away, that bearing was dry and rusty on mine needed replacing.
Max
