Please help !
bigb2192
Please help !
Post by bigb2192 »
Hi there I've got a honda vtr 1000 firestorm 98 she runs very well and when I get 2 miles from home she starts messing around and splutting and coffin and won't rev the carbs have been off and cleaned and done spark plugs and and changed the crank shaft sensor she only dose it when it hot please help many thanks tom
Re: Please help !
Start with checking that the vacuum hose is on the correct nipple at the diaphragm/fuel tap. It goes to the side behind the fuel hose, not on the bottom.
http://www.vtr1000.org/phpBB3/viewtopic ... se#p218127
Re: Please help !
Also check the vac pipe for leaks and cracks and replace if it is .
Also have you checked to see if it has fuel in it ? :Lol:
Re: Please help !
Always stay 3 miles away from home and it won''t occur...
Re: Please help !
Wicky wrote:Always stay 3 miles away from home and it won''t occur...
:lol: :lol: a lot of help you are Wicky :)
Are the rubbers that connect the carbs to the inlet manifolds done up tight? It might be worth trying another set of new spark plugs,
Re: Please help !
I just thought...it might be dead. :lol:
darkember
Re: Please help !
Post by darkember »
Could be worth checking the coil packs. The older they are can tend to falter as they get hot.
Re: Please help !
My money is on fuel starvation
Re: Please help !
My money's on him living 110 miles away from a petrol station !!! :Lol:
