Space Around Rear Bodywork?
thunderbolt
Post by thunderbolt »
I needed to replace the fittings that hold the rear cowling onto the rear sub frame (mine had odd screws & missing the gromets, etc).
So these are the bits I purchased from david Silver to do the job with.
According to the parts diagram below these are all the parts I needed to do the job. 1 metal collar (22), 1 grommet (1) and 1 screw (20).
But when I had fitted the grommet to the bodywork, inserted the metal collar and fitted the screw and tightened it all up I was left with this space shown in the picture below. The screw has tightened the metal collar hard up against the rear subframe and the bodywork with the grommet fitted to it can slide sideways on the metal collar by about 5 to 6mm.
Can someone explain if that gap should be between the lower edge of the head of the screw and the grommet and this is normal or am I missing something here.
Thanks
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
Jscobey
Re: Space Around Rear Bodywork?
Post by Jscobey »
i have no collar or anything. just a bolt that goes into the subframe. id ditch the unnecessary parts....
bigtwinthing
Post by bigtwinthing »
Mine has the bold and collar but does allow a little movement in the panel. I think its meant to.
Jscobey
Post by Jscobey »
its prolly so you dont over tighten and crack the plastic
2wheelsagain
Post by 2wheelsagain »
Mine has the gap.
Dare I ask about the wire? :think:
It may only be my opinion but it's mine!
~ My Bikes 2014 VFR1200F & 2000 VTR1000F ~
If you remove the collar you'll end up with cracked plastics! I fitted a rubber washer with mine to take up the gap but still allow movement :thumbup:
thunderbolt
2wheelsagain wrote:Mine has the gap.
I was waiting for that. I knew someone would notice.
The reason is to hold this lot up off the ground or hanging in mid air.
Don
Bikes:
1990 Suzuki VX800
thunderbolt
Watty wrote:If you remove the collar you'll end up with cracked plastics! I fitted a rubber washer with mine to take up the gap but still allow movement :thumbup:
Thanks Watty, good idea with the rubber washer. I will look out for one to take up the gap.
Excellent.
Don
Bikes:
1990 Suzuki VX800
Also suspension from vibration and all the bumps and movement the rear end goes through. The rubber washer is a good idea. :thumbup:
simo
Post by simo »
Sounds like the collar is too long mate. :biggrin
Theres A Hare in The Turnips.
Or you have later model seat unit and a early model collar .
While working on both early and late model storms I noticed the later model bikes had thinner plastics .
Don't know if that helped :confused:
thunderbolt
simo wrote:Sounds like the collar is too long mate. :biggrin
Yes it seems that way, except for the fact that this is a brand new Honda part ordered off the microfiche. Carl could be right (he usually is) they could have left a bit of space around there for movement of the rear cowling so it dopesn't fracture/crack, etc if it was mounted more rigidly. Thanks for your comments though. Appreciated.
Don
Bikes:
1990 Suzuki VX800
thunderbolt
lloydie wrote:Or you have later model seat unit and a early model collar .
Lloydie I checked out the Part # for the collar for both early and late models and the part numbers are exactly the same for all models of the VTR Firestorm. So if they did make the rear cowling of different thicknesses then they certainly did not alter the size of the collar to suit. In fact the Part # Fiche gives the size of the collar as well (6.3 x 9.5), the same for all models.
I think I will go with the rubber washer idea to take up the space or maybe a nice thick "O" ring to allow some movement but not too much.
Don
Bikes:
1990 Suzuki VX800
Not always, I'm taking a guess on this one. Did the spacers come in the genuine Honda packet with part number. There is a chance they sent the wrong ones as there are different sizes like the front tank mounts or radiators.
Lloyd it would not surprise me if they skimped on plastic on the later models as they did with the metal on the front farting (correction...fairing) brackets. I thought I'd keep that typo in. :lol: They may have required a little more space as the ECU is mounted to the subframe in the tail fairing :think: There's quite a few subtle differences between an early and late model storm. The last one I spotted was a round lug mounted at the rear on the bottom of the engine casings that''s not on early models. :Shrug:
Ooo gogglebox is just starting must stop writing. :biggrin
thunderbolt
Carl, the metal collars did arrive in the official Honda packaging, as did the rubber gromets and screws as well.
Don
Bikes:
1990 Suzuki VX800
