LEVER FITTING
- bigtwinthing
Re: LEVER FITTING
lloydie wrote:No
Keep it to the point pls
Re: LEVER FITTING
10mm spanner and a flat head screwdriver is all the tools needed .
Remove the 10mm nut and unscrew the pivot bolt ,
Remove lever and replace
Re: LEVER FITTING
I would but it's not hard !!!bigtwinthing wrote:lloydie wrote:No
Re: LEVER FITTING
Easy to do. Just make sure you have the right clearance between the level and piston the the mastery cylinder. About the thickness of a rizzla paper will do. Don't want to be warping any discs now do we?
Sent from my HTC One using Tapatalk
Re: LEVER FITTING
My man dog could do it but virts little brov can't as he's ginger !!!chric wrote:So even a spanner monkey like me can
Re: LEVER FITTING
Only if you wear your monkey helmet when fitting them.
If you don't like them I'll have them. That is off course if you won them
Re: LEVER FITTING
cybercarl wrote:Only if you wear your monkey helmet when fitting them.If you don't like them I'll have them. That is off course if you won them
- Contact:
Re: LEVER FITTING
Mine were easy to fit except I had to have the front brakes bled for some reason. I think the piston must have backed out a fraction.
Fitting = easy
Brakes = bitch
Fitting = easy
Brakes = bitch
It may only be my opinion but it's mine!
~ My Bikes 2014 VFR1200F & 2000 VTR1000F ~
Re: LEVER FITTING
That's it, put him off some more. He might sell them to me then. Their not shiny enough for Chris
Re: LEVER FITTING
have gone black this year so be keeping them for this season.cybercarl wrote:That's it, put him off some more. He might sell them to me then. Their not shiny enough for Chris![]()
Re: LEVER FITTING
Black is Soooo this season Chric!
I really like short levers, feels just the same as riding my old crosser & BMX/mountain bike, so it feels pretty natural to me.
I can appreciate you get more leverage with a longer brake lever, but when you've got Chuck Norris hands it's fine
Jamie
Re: LEVER FITTING
why have you got them then.but when you've got Chuck Norris hands it's fine
I too prefer shorties, they also have an advantage if you happen to drop your bike too as they wont snap or bend. I'd ideally like some ASV levers but can't justify the expense.
