Seat cowl bolt
carmanbikes
Seat cowl bolt
Post by carmanbikes »
Can anyone tell me what is special about this bolt or got a picture, its the one that holds the seat cowl near the tank part number 90085-MAJ-A20 , As some of you know this bike come in a box so struggling to find the right place for every bolt, Thanks in advance
Re: Seat cowl bolt
Do you meant the rear tail fairing :confused The seat cowl is the hump that sits over the pillion seat and has no bolts. The bolts in the part numbers look like the two that hold the front of the rear fairing to the subframe. They should also have top hat washer on like the ones that go on the rads or front of tank.
carmanbikes
Re: Seat cowl bolt
cybercarl wrote:Do you meant the rear tail fairing :confused The seat cowl is the hump that sits over the pillion seat and has no bolts. The bolts in the part numbers look like the two that hold the front of the rear fairing to the subframe. They should also have top hat washer on like the ones that go on the rads or front of tank.
Hi, yes it is the rear fairing and they do have top hat washers :redface
Re: Seat cowl bolt
carmanbikes wrote:Can anyone tell me what is special about this bolt or got a picture, its the one that holds the seat cowl near the tank part number 90085-MAJ-A20 , As some of you know this bike come in a box so struggling to find the right place for every bolt, Thanks in advance
spend £30 quid and get a probolt fairing kit, saves trying to get all the original bolts together....
ali...http://www.pro-bolt.com/alloy-fairing-k ... 30jWLlZpMs
ss....http://www.pro-bolt.com/stainless-steel ... 30jS7lZpMs
ti....http://www.pro-bolt.com/titanium-fairin ... 30jP7lZpMs
Re: Seat cowl bolt
Yeh but Stainless steel is £56 8O Ali is a waste of time as it's too soft and they will soon wear down when panels are removed and put back on time and time again.
carmanbikes
Re: Seat cowl bolt
That sounds a good idea, why didn't I think of that, Thanks AP
