battery spec????
battery spec????
what is the correct rated battery Ah and A amps(cold cranking amps) ??? fried my last battery with dodgy r/r??
Re: battery spec????
I am using a YTX12-BS and that seems to do the trick. Think it's 12v 10Ah and about 180A starting power if memory serves
ive been given a good battery off a fireblade 8.5 ah and 133 cca
will i get a couple of good starts out of it or should i get a battery with higher cca?
also is the blade r/r compatible as mine has fried??
Probably. Might not last long if it turns out to be underpowered. Just make sure the terminals are the right way round or bad things will happen
Not sure on the R/R. If it has the same connections (three from the stator and two more) then I would imagine so providing you can correctly identify all the wires. The plug may not be compatible with the existing bike one but some snipping it off and replacing with spade connectors with some vigorous insulation would soon sort that out.
Many threads from minds wiser than I on this subject. I just bought an R1 R/R off ebay for £20 and followed the guide in the workshop section.
cheers for advice, the blade r/r connections and code are the same so should be OK will test tonight?
only difference:
the original r/r had 7.5 on the second line,the blade r/r has 8.5 written on it??
also my original battery appears to have recharged,so i am going to check with multimeter over the next few days for voltage drop? before fitting to the bike,will use the blade one in meantime,i think i will be ok as long as not going to shop round corner and back,not giving the battery chance to recharge,take some cranking them twin engines!!
only difference:
