Page 1 of 1
Just had a test ride..
Posted: Mon Jun 16, 2014 1:41 pm
by MarkB
Hi all!
So I had a test ride on Saturday, larger tank variety with only 9k on the clock. Couldn't stop grinning when I got off!
But I have a suspicion the bike may have been sat for a few years, should I worry about that? Also is there any thing you think I should really look into on the bike to see what major work would need doing?
Thanks
Mark
Re: Just had a test ride..
Posted: Mon Jun 16, 2014 2:14 pm
by grumpyfrog
Mark,
check out the info on here regarding CCT's, If they are standard Honda ones budget in that these need replacing NOW.
Usual things, tyres, chain, battery should all be looked at. If it's been sat I would also get it serviced, fresh old and fluids can never go a miss.
Apart from that just get it..
Posted: Mon Jun 16, 2014 2:54 pm
by lloydie
grumpyfrog wrote:Mark,
Posted: Mon Jun 16, 2014 4:22 pm
by MarkB
Had read about the CCTs on here, fluids will all get changed anyway.
Any way of telling if the tensioner has already been changed before I buy?
Posted: Mon Jun 16, 2014 5:09 pm
by bigtwinthing
MarkB wrote:Had read about the CCTs on here, fluids will all get changed anyway.
you need manuals, end of, fit manuals.
Posted: Mon Jun 16, 2014 5:44 pm
by MarkB
bigtwinthing wrote:MarkB wrote:Had read about the CCTs on here, fluids will all get changed anyway.
Thanks for confirming I need manuals, but is there any way of finding out if the job has already been done before I buy? Don't think the trader will let me open her up on the shop floor to have a look...
Posted: Mon Jun 16, 2014 5:51 pm
by Wicky
Just look to see if the rear cylinder has a manual CCT fitted - the front pot is harder as it's hidden under the airbox/behind frame rail.
Posted: Mon Jun 16, 2014 7:18 pm
by Furrybiker
Manual CCT will look like a bolt sticking out of the engine on the right hand side, just above the footrest pointing towards the swinging arm. Look at VTRPIG's post "New Hangers" on the picture of the right side of his bike to the right of the Abba jack handle is a red anodised part, thats it. If it looks like a grey cone in that position, then it needs changing.
Posted: Mon Jun 16, 2014 7:40 pm
by bigtwinthing
heres my bike, zoom in and check out the blue item in the middle of the engine, thats what they look like, basically a large bolt coming out from a coloured housing.
Posted: Mon Jun 16, 2014 10:25 pm
by MarkB
From this image then I assume that's the 'cone,' and therefore will need changing, as I'll get it done properly how much am I looking at budgeting for manuals, rather than the 'fail safe' option.
Posted: Mon Jun 16, 2014 11:04 pm
by magnum
Hi markb from markc
post up were you are someone may be able to help you do the stopper mod cost nothing and give you peace of mind till you sort out sum manuals.(Glad I did front one let go only had it 3 months)
Posted: Tue Jun 17, 2014 12:46 pm
by MarkB
Different shot, but am assuming the silver slightly pointy bit sticking out the back of the engine is the Auto CCT?
Posted: Tue Jun 17, 2014 12:48 pm
by AMCQ46
yes, that is a standard auto CCT..............so you know there has not been manual tensioners fitted, but you cant tell by looking if the stopper mod has been done
Posted: Wed Jun 18, 2014 7:49 pm
by Bananaman
Hi and welcome
It's a blue one ! Excellent! They are the fastest! Lol
Posted: Mon Jul 07, 2014 11:59 pm
by VTRDark
Welcome to the forum. It's irrelevant if they are new or not if the bike has been sitting around. There seems to more of a likelihood of the cct springs breaking that have been inactive for a while. As mentioned best to either stop mod the originals or change for manuals.
