Electrical Help Please
MikaelJ
Post by MikaelJ »
So I am in the process of switching over my US lighting control switch for the European ones, as they have the on/off position and passing switch.
So far I think I got it right as most of the wires are just straight forward plug into old spot.
The 6P is a direct plug in if I read the wiring diagrams correctly
The 9P switch is also direct except I can ignore both the lb/w and o/w wires that go to the turn signals in the US version (I assume they are for constant power i.e. running lights)
The trouble I am having is in the European switch there is a bl/r wire that goes to the 20A headlight relay is not there in the harness for the US VTR.
It is instead located in the 9P start/stop switch on the right control.
My question is can I just take the bl/r wire from the left switch and combine it with the bl/r wire in the right switch so then they both go to the 20A headlight relay?
I have both wiring diagrams somewhere I can post if needed.
MikaelJ
Re: Electrical Help Please
Post by MikaelJ »
Found the wiring diagrams
MikaelJ
Post by MikaelJ »
Does nobody have at least an opinion on this? anything would be appreciated :)
Yep change the loom too :-) sorry
