I've just fitted the Krieger manual kiddies as per the rather magnifico instructions from Carl.
Having set the tension as per the instructions (5 - 7mm) and locked it all off, I got a tad paranoid about the amount of sideways movement on the camchain. Prior to removing the old tensioners, there was no sideways movement to the camchain itself (for a very good reason I'm sure). Looking at the rear pot, as you wind the motor over with a socket wrench now, the chain does appear to lift slightly off the very first section of the front cam sprocket teeth whereas prior to replacement it was tight as a nut.
Am I being overly cautious or do the original tensioners run a lot tighter?
Thanks for listening
