For winter improvement, my rear sub-frame has some rust, so I assume its steel, so strip it off, sandblast and spray, unless someone has a better idea.
Thanks Paul
REAR SUBFRAME
REAR SUBFRAME
If you find yourself in a hole, stop digging!
Re: REAR SUBFRAME
Get it powder coated, just remember to scrape a patch off for the earth on the RR.gwaynewk wrote:For winter improvement, my rear sub-frame has some rust, so I assume its steel, so strip it off, sandblast and spray, unless someone has a better idea.
Thanks Paul
