Change of gearing question
vtrjock
Post by vtrjock »
Hi guys. A quick question on gearing change/ speedo error.
Has anyone taken actual real time speedo error readings after losing one tooth on the front? Thanks.
Re: Change of gearing question
No but I did when I went +2 on the rear.
With that set up it was right at 10% on the speedo, So the +1 up front will be a little higher than that.
mik_str
Post by mik_str »
Stephan
Post by Stephan »
I posted in another topic
my speedo runs about 10% high vs a GPS and this is with standard gearing
Stephan
Post by Stephan »
yes, this 5% is only my estimate through observation, not exact number. But 10% seems to be high in my case. I have 98 year.
it helps give me some safety margin against speeding tickets so I try and forget that it is 10% high, and if I recalibrated it would lead to trouble :lol:
That's the problem with no speedo heeler.
It may be obvious but something else to note is that the margin increases as speeds rise. So 10% at 30mph is going to be 33mph and at 50 it's going to be 55mph, 70 it's 77mph and so on.
and at 100 on the clock I am only doing 91, so that saving me from a ban :lol:
vtrjock
Post by vtrjock »
Cheers guys. :thumbup:
nt1980
Post by nt1980 »
Mines way out i was going quite fast and got stopped i was doing a lesser speed thank you :silent:
