ktec fork springs
ninja636109
ktec fork springs
Post by ninja636109 »
I have just received some new k tec fork springs for the storm linear weight matched 9.0.. I'm wondering what weight oil to use with them anyone got any ideas?
budd
Re: ktec fork springs
Post by budd »
5wt -7.5wt oil with 140mm air gap :thumbup:
Storm is now gone :cry: .
ninja636109
Also I take it I just have t use the standard spacers etc
budd
Post by budd »
ninja636109 wrote:Also I take it I just have t use the standard spacers etc
the total free length of the spring and spacer should 410mm, cut spacer as necessary to acheive this IIRC K-tec springs are the same length as OE so the stock spacer should be OK.
ninja636109
Will I need a special tool to press the new fork seals in? Also I'd there a walk through posted on here as I Carnt see it I have already removed the fork legs from the bike ready
ninja636109 wrote:Will I need a special tool to press the new fork seals in? Also I'd there a walk through posted on here as I Carnt see it I have already removed the fork legs from the bike ready
Read this...
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=29710
If you have one then great. You can't beat the right too for the job. But if not, why spend money on something that gets used once in a Blue moon. Sand a little off the circumference of the old seal so it don't get stuck, and use that as a barrier to protect the new seal. You can then use a tube over the stanchion, pvc pipe or something, to tap the seal down or even use a hammer and drift to gently tap it down into place evenly.
thunderbolt
Post by thunderbolt »
Or heat the portion of the lower fork leg where the seal sits with hot water to expand it a bit to make fitment easier. Just tip it over the outside of the lower leg.
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
