I'm assuming this must be due to heat, too much of it, but what would any of you experts think has caused this
This place is usefull for various types of automotive connectors - http://kojaycat.co.uk/epages/950000457. ... _Connector
In which case....cybercarl wrote:This place is usefull, another bonus. I do like to support small businesses when I can.
Mmm now there's an idea, If only I had inheritance. If only my parents had something to leave me.Anyone got an inheritance they have no use for?
That link is very usefulfirestorm_al wrote:Check the resistances between all the yellow wires to make sure your stator is OK.
I would definetly strip back the wired and make off the connector again.
You may have to extend the wires if they are too short and I would always try and solder the connectors and use heat shrink rather than use inuulated crimps.
Well spotted and a good suggestion, but the reason you can see the copper wire strands is due to the insulating shield being burnt away by the heat. I fitted all new blue connectors (as I mentioned above) using a ratchet crimping tool in 2007. I'm pretty sure there would have been no copper wiring showing there just like the other connectors show when I did this.nt1980 wrote:You can actually see the wire on the burnt connection doesn't look like its been crimped down properly so if a few strands connect but the rest dont this will heat these strands up and course this to happen this happens quite often in mine line of work but could all so be other things as per above
