rear footrest spacer internal diameter
I need to get some spacers for the oem rear footpegs to clear the high level cans, can anyone tell me the internal diameter I will need?
8.5mm ish as its a m8 bolt that holds them on
Re: rear footrest spacer internal diameter
lloydie wrote:8.5mm ish as its a m8 bolt that holds them on
cheers lloydie....... :thumbup:
bazzashadow
Post by bazzashadow »
i have 15mm hex steel and then drilled and tapped,threaded bar and nut inside and stainless cap screws on the outside
