Rear wheel bearings
Pem Brooke
Rear wheel bearings
Post by Pem Brooke »
Hi...got an advisory on my MOT that I need to replace my rear wheel bearings. Do I need a special tool to remove the old bearings...or will they simply tap out using a bar from the opposite side? I looked on the PDF repair manual but it recommends a special Honda tool...is this really needed?
Twist it 'til it breaks, then back off half a turn.... :eh:
Rear wheel bearings
Nope just use a bar and tap them out from the other side .
Re: Rear wheel bearings
while your in there do the sprocket carrier bearing as well. it takes a pounding from the big old engine
Pem Brooke
Thanks guys...good advice. I was going to order parts from David Silver....make sense?
Stephan
Post by Stephan »
Pem Brooke wrote:Thanks guys...good advice. I was going to order parts from David Silver....make sense?
No, bearings have standard sizes, just order some quality bearings and seals in correct sizes. I would choose NTN.
If you have time, tap out the old bearings. Then look at the codes on them and you can order replacements.
Time because you will have the bike off the road until you have bearings to hand.
if you just order the bearing form David Siler you'll have the right ones to hand and can simply swap in/out.
