Penetrating oil recommendations
budd
Post by budd »
I’m about to start the restoration of a 1967 Sunbeam Alpine sports car, so I think I’m likely to need some penetrating oil to loosen the inevitable seized nuts and bolts, but before I buy the default 5ltrs of WD40 I’m wondering if there’s anything else that’s better? WD40 has traditionally been the most popular pen oil but is there anything else I should consider? because I think I’ll need all the help I can get with a car that is the best part of 50yrs old .BTW I'm more interested in bulk products ie 5ltrs rather than aerosols :thumbup:
Storm is now gone :cry: .
Re: Penetrating oil recommendations
KY jelly :-)
Murv
Post by Murv »
A +1 on plus gas. Expensive, but it works!
No idea if it's available in the sort of quantities you're after though.
popkat
Post by popkat »
I use something called (Action can) AC-90 I was given a few cans and it seems much better than WD40. they do other penetrating oils too
http://www.actioncan.co.uk/
popkat wrote:I use something called (Action can) AC-90 I was given a few cans and it seems much better than WD40. they do other penetrating oils too
+ 1 on AC90...I used to get it gratis from work (many moons & many jobs ago... :lol: )
Run out now... :(
darkember
Post by darkember »
Plus gas :thumbup: :thumbup:
Big_Jim59
Post by Big_Jim59 »
Equal parts automatic transmission fluid, brake fluid and Marvel Mystery Oil. My neighbor has a thing for old tractors. They are rust buckets when he starts to tear them down. He hits them with this mix a few days before he starts work and never has a stuck bolt and that is pure amazing.
budd
Post by budd »
found this,
http://rivperformance.editboard.com/t71 ... rison-test
similar thing 50-50 ATF mixed with acetone, I think the acetone carrys the ATF into the threads so I suppose other solvents should be just as effective, diesel, etc
Mav617
Post by Mav617 »
Plus Gas is amazing and lasts yonks as you don't use much for each application.
