Speedo at night
artee
Speedo at night
Post by artee »
Is it just me that has a problem reading the speedo at night.
Its like the figures go fuzzy.
I dont have a problem during the day. I suppose it could be the orange colour given off by the bulb.
Is there a way of changing the background colour, or am I stuck with it.
Roger
Re: Speedo at night
Cadbury64
Re: Speedo at night
Post by Cadbury64 »
I believe it is possible to use coloured LED lights to change the instrument panel colours. Here's a link where some work was done on a VFR800 panel, could be of interest to you.
http://vfrworld.com/forums/showthread.p ... instrument
artee
Re: Speedo at night
Post by artee »
Yeah.
50 posts.... I claim my pm rights.
Roger
kev64
Re: Speedo at night
Post by kev64 »
Theres an instrument LED mod you can buy off ebay, might be worth a look
artee
Re: Speedo at night
Post by artee »
I've seen those.
I just wondered if anyone on the forum had used them.
Roger
Re: Speedo at night
Red light is the best to use as it don't kill your night sight. There is a reason the Military use red lights during night op's. But seeing how the street lamps around here are not Red I not sure it will make much difference :lol:
Re: Speedo at night
Are all the bulbs working ?
If not that's why it's hard to read .
artee
Re: Speedo at night
Post by artee »
lloydie wrote:Are all the bulbs working ?
All bulbs are working.
Its the figures on the speedo, they look fuzzy, to the point I cant read them. The tacho if fine.
Roger
Re: Speedo at night
Maybe time to change to a white dial :-)
artee
Re: Speedo at night
Post by artee »
Good call.
I wasn't aware there was an alternative.
I will check it out.
Thanks
Roger
Re: Speedo at night
artee wrote:...
Are the clockfaces clear or have they got microscratches / crackled with age. Same for your visor. Also consider having a checkup with opticians.
artee wrote:...
See link in my first reply > http://www.vtr1000.org/phpBB3/viewtopic ... 61#p379465
Re: Speedo at night
It may be the clear plastic on the outer casing to the instrument panel is not so clear any more. They do get Sun damaged.
artee
Re: Speedo at night
Post by artee »
Wicky wrote:
artee wrote:...
artee wrote:...
No scratches on clocks or visor as its new.
I do need glasses to read, but not go drive. Its possible that the distance of eye to clock is right in the zone between the two.
Also at night the pupils can dilate and when they do its effectively lowering the f stop, which effects depth of field.
Have I just answered my own question?
Roger
Re: Speedo at night
Get to specksavers
