Suspension linkage seized
artee
Post by artee »
Hi
Today I decided to strip and regrease the likages.
I managed to get most of the bolts out except the one that goes through the swingarm. The bell crank wont turn on the bearings.
I got the nut off, however I cannot withdraw the bolt. It's seized solid.
I've tried to hammer the bolt out (with the nut on, of course)
Is there a technique to removing this bolt, or do I have to attack it with the angle grinder.
Roger
BrianC
Re: Suspension linkage seized
Post by BrianC »
Hello roger
Brian here from leyland - just taken all this lot off and had to use some serious heat with my butane gun - happy to help if you need help
That one on mine came off relatively easily but the needle bearings had completely rusted away - all was left of needles was bits of rust
As I say happy to help as we aren't far away
BrianC
Post by BrianC »
Btw
If you want to see seizure see my 'disaster' thread and starter motor issues
BrianC wrote:Btw
It's not a disaster, it's an upgrade opportunity.
have faith*
*and money
artee
Post by artee »
Thanks for the replies guys.
I'll try the heat and freeze method first.
New bearings anyway.
If I need help I'll give a big shout.
Thanks.
Roger
carmanbikes
Post by carmanbikes »
I got mine off with an impact gun, The impact action did the trick :thumbup:
Heat and a big hammer again .
When I had trouble with one ,I found it easier with the swing arm removed.
darkember
Post by darkember »
lloydie wrote:Heat and a big hammer again .
Typical northerner. Just hit it with a hammer if that don't work get a bigger hammer :lol: :lol: :lol:
StuartWags
Post by StuartWags »
i had one that was the same
did hammer, heat, soaked for a week in wd40 bath, more hammer more heat, then tried welding a big bar to it to try to get it moving........
in the end i had to accept defeat and the disk cutter came out
was not happy it was sold to me via ebay as good working order
artee
Post by artee »
I don't call Coventry northern.
BrianC
Post by BrianC »
What type of heat are you using roger ???
And as others before me have said don't get it mad hot then cool it too quickley
artee
Post by artee »
Bolt is now free.
used a small butane torch on the swingarm where the allen key sided bolt goes through, then drifted the bolt from the other side.
Now I'm waiting for parts.
Roger
bigtwinthing
Post by bigtwinthing »
It Is !
artee
Post by artee »
Not to me it isn't.
BrianC
Post by BrianC »
Well done Roger
My northern suspension brother !!'!!!!!!!!!
Hope you are checking the whole damned lot
Brian
