Following the instructions I turned the crank until both cams were pointing up and inwards and the R-T mark aligned and the chain wheels seem a way off the marks
Just to illustrate some pics below:
And this is what I am seeing on the inlet side
I have quadruple checked the RT mark and still the same. It looks like the Exhaust side is similarly out.
I know this did have new CCT fitted in the nearish past - maybe the muppet got it wrong - ie to those other marks?
The engine turns OK, with no bashing noises, it was running fine when I got it, and the fronts look in perfect alignment. I'm presuming from the quietness when running and the absence of clashing noises that I am not getting any metal to metal !!!!
Looks like I am stalled again!!!!
