shuddering from front
thomas111
Post by thomas111 »
Hi guys was out this morning started to apply the front brake and got shuddering so could it be a disc or a sticky caliper
shahwales
Re: shuddering from front
Post by shahwales »
Old discs? After markets? Pulsating at lever? Any different at higher speed?
A sticky caliper would eventually cause a warped disc
mine done that. got so bad at a track day last year i couldnt see because it was juddering so bad. changed the discs and that sorted it.
darkember
Post by darkember »
Also check the headstock bearing
thomas111
Post by thomas111 »
Head stock bearing just done at mot ok will go down the disc route
thomas111 wrote:Head stock bearing just done at mot ok will go down the disc route
Do the nut & bolt spin the bobbin trick first...Clean them all up & see if it makes a difference.
Then look at the callipers too make sure a piston isn't sticking, best check it as it will soon fek the new discs if it is sticking ... 8O
thomas111
Post by thomas111 »
Thanks guys will give them a clean with brake cleaner
Bananaman
Post by Bananaman »
+1 :thumbup: I had exactly the same problem, cleaned all the bobbins up and jobs a goodun :beer:
Four wheels move the body,
Two wheels move the soul.
thomas111
Post by thomas111 »
Thanks guys
