The final waiting and praying begins....
mik_str
Post by mik_str »
dropped off the totality of the parts at the garage today for the rebuild (balanced crank, bearings, gaskets,...). I sure hope everyone gets it right this time....... this 2.5 month dry spell sucks....... am having them play with the cams; will be putting the Mori Stg 1 exhaust cam in the intake position (249 degrees, 10.1mm lift - making it half-way between the OEM and Mori intakes). I asked to have it set at 102 degrees. On the exhaust side, OEM exh. cams timed at 108 degrees (107.5 is OEM spec). This gives me a total of 37 degrees overlap, and combined with the early intake timing, should move the power downwards slighty (torque peak at maybe 6500 rpm), but placing it right where I want it, in the critical (to me) 3500 to 7000 rpm range, with instant response and torque for roll-ons and pulling out of corners; I seldom ever rev it to 8000 or higher so a surge of power at 8K+ is of little use to me....... here's to hoping it works out.
On another note, getting the bike back will allow me to bolt up and test that HRCPro-replica subframe brace..... Hope to have the HDJ-equipped carbs back from Factory Pro any day now too (or so I hope anyhow).... more stuff that looks good on paper....
anyhow, me rant is overrrrrrrrr for today.... :)
Re: The final waiting and praying begins....
Wishing the all the very best Micky with the engine rebuild, fingers crossed it all goes well for you,
Yeh I second that. :thumbup:
Sounds good, not too extreme.
Hope all goes well for you Mick
mik_str
Post by mik_str »
thanks gents.... :thumbup:
Good luck and hope it's done right for you this time
fingers crossed for you micky, it's about time your luck changed for the better.... :thumbup:
mik_str
Post by mik_str »
so, back from Phase I of my summer vacation (with my daughter), ever-hopeful to find my bike up and running upon my return......... No sir not to be.... (yet again!), shop decided to replace the head gaskets (not sure it was necessary, but alas, the heads are off so they need replacement now).... more waiting....... I am beginning to wonder if I will get thing back before the snow flies......
mik_str wrote:so, back from Phase I of my summer vacation (with my daughter), ever-hopeful to find my bike up and running upon my return......... No sir not to be.... (yet again!), shop decided to replace the head gaskets (not sure it was necessary, but alas, the heads are off so they need replacement now).... more waiting....... I am beginning to wonder if I will get thing back before the snow flies......
:( ....... :thumbdown:
