spring
Moderator: VTRDark
countrymick
spring
Post by countrymick »
anyone got an unwanted 850lb rear spring in there shed to fit a nitron shock..beer tokens awaight :D
Re: spring
I might have exactly that in the shed. Will go and check
Re: spring
Yup, 860lb spring here. It is the shorter spring to go with the hydraulic preload adjuster, but I think you have enough screw adjustment to use it, if not you might need a 25mm spacer to fill the gap.
Cost £70 inc postage from Nitron, so how about £50 inc post?
countrymick
Re: spring
cheers al,yep plenty of adjustment there to.will pm you :thumbup:
