water pump test ?
water pump test ?
How do I test the water pump without draining coolant or removing covers, am thinking pull off carb heater hose and see if it shoots out ?
Re: water pump test ?
Steve, there is no way that the water pump will cause your brakes to pulse, no way, none
Different"Varastorm"]Steve, there is no way that the water pump will cause your brakes to pulse, no way, none
[/quote]
Oh, I would never have guessed
Different prob, I have several I am working through
What's on earth makes you think the water pump has stopped working
If you have the fairing off, remove the radiator cap and start the bike, the coolant you should see in the radiator now the cap has been removed will be swishing about almost like a jacuzzi
If the water pump has stopped working, the coolant should be still,
Have sorted it Chris, and thats exactly what I did, its related to another problem am working onsirch345 wrote:What's on earth makes you think the water pump has stopped working![]()
If you have the fairing off, remove the radiator cap and start the bike, the coolant you should see in the radiator now the cap has been removed will be swishing about almost like a jacuzziIf the water pump has stopped working, the coolant should be still,
