Made a big rooky mistake please help
Hi guys right my problem is this, my mates been going on about riding along and hitting the kill switch and turning it on to create a backfire which I never heard of but tried it first time nothing second time heard it backfire straight after I heard a rattling noise then felt like it was running on one cylinder then conked out. After that put it in neutal tried to fire it up i heard the starter relay or solenoid clicking but lights dim but that's it. What have a STUPIDLY possibly done?
I know I'm guna get some grief for this so crack on.
Re: Made a big rooky mistake please help
Front cct has let go and bent valves etc. !!!! ????
Basically in essence I could be looking at a very expensive learning experience.
Only one thing that rattles on these bikes :-(
Have you fitted manuals ccts or done the stopper mod ?
Kill switch bangs are fun , I loved doing them in tunnels lmao
Not sounding good mate.
Sounds like front cct rattle then it dies.
oops
oops
Everything good is bad
Everything bad is good
Hi lloydie no mate haven't got around to doing them yet. What's the possible reason for this happening apart from me doing that kill switch thing.
The spring inside them is shite & can snap at any time...scooke wrote:Hi lloydie no mate haven't got around to doing them yet. What's the possible reason for this happening apart from me doing that kill switch thing.
So potentially could be a bin the bike time?
You could rebuild it, new head or engine. Or sell it on cheap with a knackered engine and buy another, and do the CCT's
Sent from my SM-A300FU using Tapatalk
- turbo_billy
If the CCT has let go then with any luck just head off, replace bent valves, new gasket, rebuild and a set of manual CCTs. Couple of hundred should see you good for all that. Depends where you are located. Tony Mon is the man down south to get the work done, if you don`t feel up to doing it yourself.
They made of chocolate!scooke wrote:Hi lloydie no mate haven't got around to doing them yet. What's the possible reason for this happening apart from me doing that kill switch thing.
Or trade it in for my fast teal one and I've got me self a project!!scooke wrote:So potentially could be a bin the bike time?
you might be lucky ,when mine went it did no damage to valves/pistons. I just got manuals fitted and 13,000 later still going strongturbo_billy wrote:If the CCT has let go then with any luck just head off, replace bent valves, new gasket, rebuild and a set of manual CCTs. Couple of hundred should see you good for all that. Depends where you are located. Tony Mon is the man down south to get the work done, if you don`t feel up to doing it yourself.
Don't panic!
Before you go into full cct failure mode (which is no biggie anyway) check the usuals- does it have a spark, is there fuel flowing?
Where are you in the UK?
- bazzashadow
Kill switch bangs are fun , I loved doing them in tunnels lmao[/quote]past
I do it all the time
my son`s mate was in the football ground and heard me outside going past killing the switch
