Are there any after market engine mount to frame adjusters?
Ant
Post by Ant »
Hello everyone, just got myself a storm last weekend. Stripped it all down already and ony had 3 bolts that were a bugger to get out (soak every bolt in WD40 for days before, feeling a bit smug 8) ). Unfortunatly one of thr ones that got stuck was the front left engine mount adjuster. I snapped the fins off the end of it....
Are there any options for these in terms of after market parts or is only the O.E.M bits?
If it's broken; should it move? Yes: Use WD40 No: Use cable ties. Now it's fixed!
Re: Are there any after market engine mount to frame adjuste
Only oem unless you have some custom made
Ant
Post by Ant »
lloydie wrote:Only oem unless you have some custom made
Cheers Lloydie, nice one! Will have to get onto my local Honda dealer then...
Ant wrote:Hello everyone, just got myself a storm last weekend. Stripped it all down already and ony had 3 bolts that were a bugger to get out (soak every bolt in WD40 for days before, feeling a bit smug 8) ). Unfortunatly one of thr ones that got stuck was the front left engine mount adjuster. I snapped the fins off the end of it....
Fins?
Do you mean the wings that surround the oval frame bolt?
That's not a disaster.
The adjuster screws into a threaded drilling/boss in the frame. It's not untypical for them to seize.
But its fairly easy to file flats on the inboard flared boss, to eable you to get Stilsons onto it, and overcome the seized section. If that doesn't work, hacksaw through the adjuster and the bolt itself and remove the engine.
You can then remove the bolt sections.
Once they're out of the way you can slide a hacksaw blade through the adjuster interior. Make two slots around 120 degrees apart, and then after a fair bit of effort you can slice through the steel adjuster, down to the point where the section is so thin you can lever a section out. Then it relaxes the remaining section and it can be extracted.
Then you need a new adjuster- i think I have one in stock, if you find it difficult to get one quickly.
Ant
Post by Ant »
tony.mon wrote: Do you mean the wings that surround the oval frame bolt?
Hello Tony,
Yeah that's the one, snapped the wings. I've got the bolt out of the centre but the adjuster is pretty seized in there. I've not gotten round to looking at the frame yet but the hacksaw idea is a good one will give that a go. Cheers for the advice!
Ant
Post by Ant »
Just found the Honda part number; 90117mbb000
From here:
http://www.cmsnl.com/honda-vtr1000f-fir ... ml#results
Just in case anyone needs it in the future.
