All back in and tightening up the cam cover bolts and snnnnnap. baldrocks
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_182426_zpsvbtfgiel.jpg)
Probably going to be a nightmare as its so small. Ah well here goes. Use dremel with a cone shaped grinding head to make a start point for a drill bit
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_182533_zpshimisssm.jpg)
High quality drill bit goes through nice a easy
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_183938_zps9vwekd1h.jpg)
Next is a small extractor
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_184123_zpsabojwsha.jpg)
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_184247_zpsnt8gsr24.jpg)
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_190514_zpsatjcg9x7.jpg)
Voila! Can't believe it came out so easily
Use a tap to clean up the threads
That is a stud extractor holding the tap........the tap was not long enough to allow me to use the normal handle
So a bit of lateral thinking got the job done
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_191037_zpsps6t5ihx.jpg)
![Image](http://i93.photobucket.com/albums/l76/sadFlatline/IMG_20160222_191151_zpstq63ozg8.jpg)
Screws in nicely
Now to get a new bolt
