SWINGING ARM CHANGE
pmd31421
SWINGING ARM CHANGE
Post by pmd31421 »
Hi I want to fit a new swinging arm and shock to my VTR1000.
What`s the best way to support the back end so I can remove the old swinging arm ? The bike is siting on an Hydraulic platform so the front end is clamped . But I can`t see a way of supporting the rear .
Re: SWINGING ARM CHANGE
I use a car jack with a plank of wood at the rear of the sump then tie the rear of the bike to something on each side and it holds it fine.
StormyRob
Post by StormyRob »
I left the front wheel on and took the rear off...then put a jack and piece of wood under sump. It balanced towards the front and I was able to take swingarm off then.
The second time I tied the subframe to the roof of the garage.
VTR Phoenix
Post by VTR Phoenix »
Defo strap the rear of the bike either from above on each side or on each side with straps. You have to use a bit of force to get the swingarm spindle out so don't take the chance of doing it without rear anchorage. I put the front on paddock stand. wood sheet on trolley jack under sump and ratchet strapped the left and right side of the subframe. worked a treat
pmd31421
Post by pmd31421 »
Brill thanks for advice , I'm be removing this afternoon . Cheers
bazza696
Post by bazza696 »
I used my rear paddock stand o lift the bike, made some wooden blocks to use as packers under the sump, then take the paddock stand away. I have crash bungs, so made two pieces of wood with a V cut in the top to wedge under the crash bungs to make is stable.
Jesus, man, how fast were you going when you ran into the kid on the swing?
ABBA stand fitted to the engine mounts above the swingarm pivot bolt. Details are in the read me for new members.
Did mine like that a couple of weeks ago. Wooden supports under the sump enabled me to take the forks off too. Stable enough.
Stratman
Post by Stratman »
Aluminium stepladder used as an A frame and the bike held by rope.
tony.mon wrote:Jesus, man, how fast were you going when you ran into the kid on the swing?
:lol: that's one of your better ones Tony :clap:
