Anyone got any suggestions?
Tried Vehicle Wiring Products but they've not got the right terminal. Don't fancy trying to open up the clamps and re-using.
Knackered a terminal in rear light connector block
- freeridenick
Re: Knackered a terminal in rear light connector block
Take a quick pic of the offending conector block.freeridenick wrote:Anyone got any suggestions?
I have a knackard cut to bits loom. I can chop off the required block with a few cm's of wire & you can splice it in.
Is it the flat white conector that goes into the rear light bulb socket ?
i have managed to push the pins out of the block and solder the wires on before. but they are delicate after that
- freeridenick
That's the one, white/green, brown and green wires iirc. Will take a picture tomorrow. Thanks for the offer.MacV2 wrote:
- freeridenick
Offending item
You have a PM Nickfreeridenick wrote:Offending item
